wnulf Posted March 31, 2021 Share Posted March 31, 2021 I have a 4 cylinder 1988 Comanche 4 speed. I want to put a inline 6 engine in it or maybe just a regular V6. Does any one know what years are most compatible and what is the difficult level of the swap over Link to comment Share on other sites More sharing options...
Pete M Posted March 31, 2021 Share Posted March 31, 2021 technically it's not all that difficult since it all bolts in, but the short answer is that you'll be more or less completely gutting your truck and replacing it with everything from an XJ. Link to comment Share on other sites More sharing options...
Coyote Posted March 31, 2021 Share Posted March 31, 2021 19 minutes ago, wnulf said: I have a 4 cylinder 1988 Comanche 4 speed. I want to put a inline 6 engine in it or maybe just a regular V6. Does any one know what years are most compatible and what is the difficult level of the swap over It depends on your definition of difficult. All engine swaps are not going to be fun, quick or easy. BTW you'll have to swap the tranny as well. If you're going through all that trouble I'd go all out and take a '91 -96 Cherokee 4.0, AW4, transfer case (hopefully a NP 242, but a NP231 will work too), front and rear axles, wiring harness and instrument cluster. '91 and up are 4.0 HO years, OBD II started in '96 (probably the best year). '97 and up use a different instrument cluster that won't just bolt in. Link to comment Share on other sites More sharing options...
Coyote Posted March 31, 2021 Share Posted March 31, 2021 Forgot to add you'll need the ECU and TCU as well. Basically you'll just be using your Comanche for the frame and body, everything else will be Cherokee. The 4 door Cherokees use the same front doors as Comanches, basically a one for one swap (great time to upgrade to electric locks, windows and mirrors). Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 31, 2021 Share Posted March 31, 2021 It’s also an option to do stand alone efi either using the 4.0 HO harness and ecu from 91-95 or a stand alone unit from Holley, mega squirt, hall tech etc. That way you can keep your engine running happy and your original wiring in-tact. The factory harnesses just fused together chasis and efi harnesses. They can be separated though as it doesn’t actually take very much to run an HO engine Link to comment Share on other sites More sharing options...
