Wvmountandrifter Posted March 26, 2021 Posted March 26, 2021 iv'e got a 4 cyl 86 jeep comanche and I'm wondering if a Cherokee engine will bolt in or do i need new mounts? would like to upgrade to 6 cyl. thanks if you could help.:)
Dammerung Posted March 26, 2021 Posted March 26, 2021 iv'e got a 4 cyl 86 jeep comanche and I'm wondering if a Cherokee engine will bolt in or do i need new mounts? would like to upgrade to 6 cyl. thanks if you could help.:)I think you’ll need new mounts and depending on the time when your 86 was made, the rear firewall may need to be modified. I’m not sure about how the transmissions bolt up or which transmissions came with a 2.5 in 861988 Jeep Comanche Pioneer4.0 Liter w/ AW4 2WD
Wvmountandrifter Posted March 26, 2021 Author Posted March 26, 2021 1 minute ago, Dammerung said: I think you’ll need new mounts and depending on the time when your 86 was made, the rear firewall may need to be modified. I’m not sure about how the transmissions bolt up or which transmissions came with a 2.5 in 86 1988 Jeep Comanche Pioneer 4.0 Liter w/ AW4 2WD thanks for the info.
eaglescout526 Posted March 26, 2021 Posted March 26, 2021 10 minutes ago, Dammerung said: I’m not sure about how the transmissions bolt up or which transmissions came with a 2.5 in 86 AX4/AX5 and the Chrysler A900 series.
