I'm having a real hard time sourcing a replacement yoke for the drive shaft connected to my Dana 44 rear. There's no identifying info on the yoke itself. I attached some pictures. If anyone has a source, or one for sale, or just any info in general please help me out. Thanks!
Go to rockauto.com
Select your year model.
Search on "Drive Shaft Pinion Yoke".
Half a dozen options to choose from.  The front Dana 30 and the rear Dana 44 use the same yoke.  The Dana 35 uses a different yoke so make sure you don't pick one of those.
10 minutes ago, Not said:
That looks promising. Thanks!
what has gone wrong with yours?
The metal is pitted and not smooth so it doesn't seal properly and is leaking. You can see the pitted metal in the 3rd pic.
