Tyler Posted March 6, 2021 Share Posted March 6, 2021 Hello! Just finishing up mounting my add-a-leaf, and as I’m torquing the bottom nut for the shock, the old screw busted. I was hoping to get the name of this bracket that holds the leaf springs since I’m having a hard time finding one to replace it. Also, if anyone has any recommendations for good leaf springs to eventually swap out (currently have a 3 inch lift), that would be great as well. Thank you. Link to comment Share on other sites More sharing options...
Pete M Posted March 6, 2021 Share Posted March 6, 2021 lower shock mount. it's specific to MJs, is mirrored left to right (meaning if you snapped a drivers side, you need a drivers side), and only available used. another option is to slice off the offending shock bolt and just weld a new bolt in its place. Link to comment Share on other sites More sharing options...
rylee144 Posted March 6, 2021 Share Posted March 6, 2021 shock mount Ebay has a set, https://www.ebay.com/itm/Jeep-Comanche-MJ-1991-Rear-Leaf-Spring-Plate-Factory-OEM/114616653289?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200818143230%26meid%3D2c00423a5a7b40a8919f3373f5442590%26pid%3D101224%26rk%3D3%26rkt%3D5%26mehot%3Dnone%26sd%3D114390700399%26itm%3D114616653289%26pmt%3D0%26noa%3D1%26pg%3D2047675%26algv%3DDefaultOrganic%26brand%3DJeep&_trksid=p2047675.c101224.m-1 Also, you could weld on a new peg for the shock. I bet you could get a set from a junkyard for $20 bucks or so too. Facebook Market Place has a lot of Comanche part outs so you can prolly get a set there too. Hope that helps and that is what your talking about 25 minutes ago, Tyler said: Hello! Just finishing up mounting my add-a-leaf, and as I’m torquing the bottom nut for the shock, the old screw busted. I was hoping to get the name of this bracket that holds the leaf springs since I’m having a hard time finding one to replace it. Also, if anyone has any recommendations for good leaf springs to eventually swap out (currently have a 3 inch lift), that would be great as well. Thank you. Link to comment Share on other sites More sharing options...
Tyler Posted March 7, 2021 Author Share Posted March 7, 2021 43 minutes ago, Pete M said: lower shock mount. it's specific to MJs, is mirrored left to right (meaning if you snapped a drivers side, you need a drivers side), and only available used. another option is to slice off the offending shock bolt and just weld a new bolt in its place. Much appreciated! Have a great weekend 👍 Link to comment Share on other sites More sharing options...
Eagle Posted March 7, 2021 Share Posted March 7, 2021 Some models of Monroe shocks used to come with mounting bolts/studs that would be perfect to replace a busted factory mount. I don't know if Monroe sells them separately. Link to comment Share on other sites More sharing options...
