Here’s another thread on starting issues....
’92 4.0 4wd
last week it ran ok for a short drive. The next day it started and ran for about a minute, then quit. It was very rough, like a misfire or missing a cylinder.
now it cranks strongly but doesn’t start, doesn’t even sound like it wants to start. I depleted the battery trying and had to charge it.
I confirmed spark on all 6 spark plug cables.
I also drained the tank and added 5g fresh gas.
I hear the fuel pump activation and fuel drips when I unplug the line at the rail.
I plan to test fuel pressure and compression as soon as I get the test equipment.
thoughts?
Sounds like the timing could be off, but I'm not sure how. That was an issue with my blue truck when we swapped the motor--the timing was 180 degrees off and it wouldn't start.
Update...
I tested fuel pressure and it registers 40 psi while cranking.
And turning the key to activate pump doesn’t register, and immediately after cranking it drops back to zero.
  • 86customanche changed the title to Crank no start - fuel pressure regulator?
pull the spark plugs see if one looks wet.
Are they original injectors?
Ohm out each injector, they all should be about the same resistance
A few of the plugs looked wet.  Injectors 1-4 all ohm’d ok. Pita to get to 5&6.
I cleaned an old set of plugs and tested them, then installed them and it started fairly easily.
pic is of plugs removed.
