Muncher Posted February 9, 2021 Share Posted February 9, 2021 i saw something on a tj forum where they took a bolt and welded it to the transfer case shifter and made it stick straight up instead of the bend, would this be possible on a mj? or does anyone know if the lever is the same in a tj as in a mj? Link to comment Share on other sites More sharing options...
Jesse J Posted February 9, 2021 Share Posted February 9, 2021 I don't see any problem why it wouldn't work Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 9, 2021 Share Posted February 9, 2021 Well the XJ/MJ T-case shift handle is used up until 96 for the XJ. And thats all that it fits. Buttttt that being said, the handles look very similar if you remove them from their assemblies. Link to comment Share on other sites More sharing options...
Muncher Posted February 9, 2021 Author Share Posted February 9, 2021 well the guy just welded a bolt to the handle after cutting some of the orginial off so as long as i could do that it would work, Link to comment Share on other sites More sharing options...
Muncher Posted February 9, 2021 Author Share Posted February 9, 2021 10 minutes ago, Jesse J said: I don't see any problem why it wouldn't work well thats good,. i think I'm going to do this soon as a project to keep me busy during winter Link to comment Share on other sites More sharing options...
Jesse J Posted February 9, 2021 Share Posted February 9, 2021 1 minute ago, Muncher said: well the guy just welded a bolt to the handle after cutting some of the orginial off so as long as i could do that it would work, yeah that seems like it work fine. Maybe not with the trim piece. any reason why you want to? Link to comment Share on other sites More sharing options...
Muncher Posted February 9, 2021 Author Share Posted February 9, 2021 3 minutes ago, Jesse J said: yeah that seems like it work fine. Maybe not with the trim piece. any reason why you want to? yea if not i would have to find some boot to fit in there. but basicaly i would just like the circular ball shifter and ive always liked the classic look of a dual lever system in a truck that has a manual. and i guess it would be a little easier shifting into 4x4 Link to comment Share on other sites More sharing options...
Jesse J Posted February 9, 2021 Share Posted February 9, 2021 1 minute ago, Muncher said: yea if not i would have to find some boot to fit in there. but basicaly i would just like the circular ball shifter and ive always liked the classic look of a dual lever system in a truck that has a manual. and i guess it would be a little easier shifting into 4x4 huh I guess that makes sense. it is classic that's for sure just measure it out so it doesn't get in the way of your stick Link to comment Share on other sites More sharing options...
Muncher Posted February 9, 2021 Author Share Posted February 9, 2021 Just now, Jesse J said: huh I guess that makes sense. it is classic that's for sure just measure it out so it doesn't get in the way of your stick yeah i would probably have it around a inch shorter then my shifter. Link to comment Share on other sites More sharing options...
Jesse J Posted February 9, 2021 Share Posted February 9, 2021 1 minute ago, Muncher said: yeah i would probably have it around a inch shorter then my shifter. well measure and weld Link to comment Share on other sites More sharing options...
Muncher Posted February 9, 2021 Author Share Posted February 9, 2021 Just now, Jesse J said: well measure and weld i will. ill have to document it to once i do it and maube put it in on here Link to comment Share on other sites More sharing options...
Jesse J Posted February 9, 2021 Share Posted February 9, 2021 2 minutes ago, Muncher said: i will. ill have to document it to once i do it and maube put it in on here would love to see it Link to comment Share on other sites More sharing options...
