Garza Posted January 17, 2021 Posted January 17, 2021 I have 2 Comanches 1988 and a 1989. Both in registery now. Since this one will have more of a build I'll keep to it for now. Current state: 1988 Short bed 2wd, no engine/trans. Build plan: 4.0/42rle/231 fuel tank from a 2005 LJ Late model XJ dash HPD30 front axle, 4.88, Powertrax Grip-Pro, Black Magic Big Brakes, Revolution Gear Chromoly axle shafts. Ford 8.8 rear, 4.88, ARB air-locker Suspension: On the fence of a full RockJock 4" front (all of which I have) or a 3 link front with a combo of the RJ parts. Rear spring over on stock 2wd springs with Ruffstuff u-bolt eliminate Fox 2.0 Resi. custom tuned shocks all around. 33" BFG KO2 or KM3 on the Challenger wheels below Paint/body, bumpers ect..will come at the end
Garza Posted January 17, 2021 Author Posted January 17, 2021 Today I cleaned the factory brackets off the 8.8 and rolled it under the rear for test fitment. The gears and locker are already in, will wait to put the new cover on until it's final install. I'm using RuffStuff u-bolt eliminator perches for the spring over and shock mounts will come once axle is in and suspension cycled.
MiNi Beast Posted January 17, 2021 Posted January 17, 2021 yeah i loved my ube 8.8 setup. was a great swap candidate. i also pushed my forward a inch as well to off set the difference in pig length. Thanks for sharing your adventures. Gotta love these great MJs of ours. truly a give and take relationship with these jeeps.
89 MJ Posted January 18, 2021 Posted January 18, 2021 1 hour ago, MiNi Beast said: truly a give and take relationship with these jeeps. Yeah, you give it money and it takes your money
