OEM towhooks
23 minutes ago, 89 MJ said:
Are these OEM tow hooks?
They appear to be, you might want to look a little closer to see if all the factory parts are there.  If they were added by a previous owner, it's possible not all the correct reinforcement and mounting brackets were added.  All the factory hooks I have seen were chrome plated and marked with a 10,000 lb rating.
20 minutes ago, eaglescout526 said:
Aftermarket brackets also don't have the extension holes for the hidden winch.
Thanks guys. I will do some checking in the coming days.
