Tominator Posted December 31, 2020 Posted December 31, 2020 Year, Make, Model. 1986 Comanche Truck Image, if available Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase. 2.5 Ltr standard transmission Build date: (its on the driverside door sticker, in the form of month and year) Current Location: Region will do, state, and area of state. Alexandria VA Status: Is it still on the road, is it in the junkyard? Project awaiting work? Being worked on Notes: Anything that makes this comanche different from the rest. Skid plates, plows, lights, bumpers, weird factory options... Would also be a good place to note the exterior color, and the interior color and combination, IE, Bench or buckets, Vinyl or cloth, column shift or floor shift. Current owner: Well, you know. Put down who has it, the yard its in, or anything of that sort.
eaglescout526 Posted December 31, 2020 Posted December 31, 2020 If you change the title to the VIN, I or a couple others can get you a build sheet and date.
Tom conway Posted February 23, 2021 Posted February 23, 2021 On 12/30/2020 at 8:19 PM, eaglescout526 said: If you change the title to the VIN, I or a couple others can get you a build sheet and date. 1JTHX6510GT038046. Sorry this took a while. Build sheet will be great. Impossible finding some electrical components.
Pete M Posted February 24, 2021 Posted February 24, 2021 29 minutes ago, Tom conway said: 1JTHX6510GT038046. Sorry this took a while. Build sheet will be great. Impossible finding some electrical components. would you like me to combine "Tom conway" with "Tominator"?
eaglescout526 Posted February 24, 2021 Posted February 24, 2021 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR DCK 4SPD MANUAL TRANS - AISIN SEIKI DSA LIMITED SLIP DIFFERENTIAL EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HC0 All Vehicles W/O Air Cond HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) Build date 9/5/85 Body code JL62
