1JTHX6510GT038046
Tominator
Year, Make, Model.  1986 Comanche Truck
Image, if available
Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase. 2.5 Ltr standard transmission
Build date: (its on the driverside door sticker, in the form of month and year)
Current Location: Region will do, state, and area of state. Alexandria VA
Status: Is it still on the road, is it in the junkyard? Project awaiting work? Being worked on
Notes: Anything that makes this comanche different from the rest. Skid plates, plows, lights, bumpers, weird factory options... Would also be a good place to note the exterior color, and the interior color and combination, IE, Bench or buckets, Vinyl or cloth, column shift or floor shift.
Current owner: Well, you know. Put down who has it, the yard its in, or anything of that sort.
  • 1 month later...
  • Pete M changed the title to 1JTHX6510GT038046
29 minutes ago, Tom conway said:
1JTHX6510GT038046. Sorry this took a while. Build sheet will be great. Impossible finding some electrical components.
would you like me to combine "Tom conway" with "Tominator"?
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT
-ZZ
BAC 75 AMP ALTERNATOR
BCQ Battery - 750 Amp Maintenance Free
CGX Head Restraints-Outboard Seating, RR
DCK 4SPD MANUAL TRANS - AISIN SEIKI
DSA LIMITED SLIP DIFFERENTIAL
EPD ENGINE - 2.5L I4 TBI GAS
GAC ALL WINDOWS - TINTED GLASS
GSC MIRROR - RIGHT BLACK
HC0 All Vehicles W/O Air Cond
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JJA CIGAR LIGHTER - FRT COMP
LMA HALOGEN HEADLAMPS
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
Build date 9/5/85
Body code JL62
