eaglescout526 Posted December 23, 2020 Share Posted December 23, 2020 I am looking for the shift level for a manual trans. Doesn’t matter which transmission as they are all the same. The threads on Chunk for the shift knob are snapped clean off. Link to comment Share on other sites More sharing options...
Torq_Shep Posted December 23, 2020 Share Posted December 23, 2020 1 minute ago, eaglescout526 said: I am looking for the shift level for a manual trans. Doesn’t matter which transmission as they are all the same. The threads on Chunk for the shift knob are snapped clean off. I have had this happen twice on two different jeeps. I have good luck welding a bolt upside down at the top of the shift lever to fix it without a later failure. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 23, 2020 Author Share Posted December 23, 2020 8 minutes ago, Torq_Shep said: I have had this happen twice on two different jeeps. I have good luck welding a bolt upside down at the top of the shift lever to fix it without a later failure. Possible route I could take. Thanks for that. Link to comment Share on other sites More sharing options...
BeatCJ Posted December 23, 2020 Share Posted December 23, 2020 I have 2 AX-15s sitting in my garage. I doubt my BA10 will be worth less without a lever. The AX-15 and the BA10 Shift lever are the same? Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 23, 2020 Author Share Posted December 23, 2020 3 minutes ago, BeatCJ said: I have 2 AX-15s sitting in my garage. I doubt my BA10 will be worth less without a lever. The AX-15 and the BA10 Shift lever are the same? Looking at the catalog, there are three different numbers. One for the four cyl, one for the BA and the other for the 15. I wish I knew what made them so different but it could be the angles in the lever. I might check AMC salvage but it seems like manual trans stuff is very popular. Link to comment Share on other sites More sharing options...
BeatCJ Posted December 23, 2020 Share Posted December 23, 2020 OK. If one of AX-15 shift levers can help, let me know. I'm a while from making the swap, and I think I may keep a spare. My son's Cherokee has an AX-15, too. Link to comment Share on other sites More sharing options...
jdog Posted December 24, 2020 Share Posted December 24, 2020 I've got a spare ax15 if beatcj doesn't want to break apart one of his. Link to comment Share on other sites More sharing options...
