ratty Posted December 3, 2020 Posted December 3, 2020 Like it says. Can't seem to find it. It's pretty constant. I can hear it the loudest when my foot is off the throttle and cruising. IMG_7181.mov IMG_7177.mov IMG_7180.mov
SVPete Posted December 4, 2020 Posted December 4, 2020 Can't really hear anything for certain. Do you have needle bounce on your speedometer?
ratty Posted December 4, 2020 Author Posted December 4, 2020 2 hours ago, SVPete said: Can't really hear anything for certain. Do you have needle bounce on your speedometer? Yeah! But I'm pretty sure that just started
mjeff87 Posted December 4, 2020 Posted December 4, 2020 The speedometer cable/housing is secured by a small clip that bolts to the frame side UCA bolt underneath. Check that clip to see if it's still attached. If it's not, the cable can bounce around, tapping the UCA and making noise.
ratty Posted December 4, 2020 Author Posted December 4, 2020 10 hours ago, MiNi Beast said: check driveline speedo cable 2 hours ago, mjeff87 said: The speedometer cable/housing is secured by a small clip that bolts to the frame side UCA bolt underneath. Check that clip to see if it's still attached. If it's not, the cable can bounce around, tapping the UCA and making noise. Good to know. Thanks!
