sethrose2010 Posted November 27, 2020 Share Posted November 27, 2020 1991 Jeep Comanche 4.0 AX-15 231 LP Dana 30 Dana 44 Short wheel base ( will add the build date when I get home ) In New Jersey Daily driver SOA 6.5” lift 35” tires JCR winch bumper manual cad set up. Upgraded 231 with 1.25” chain and 6 gear planetary set. Detroit true trac in the rear. Speedliner (bedliner) yellow GMC Canyon tonneau cover. Was originally white with gray interior but I’m going to swapping to saddle and black. Seth Rose Link to comment Share on other sites More sharing options...
jdog Posted November 27, 2020 Share Posted November 27, 2020 (edited) body: jl61 Build: 9/21/90 *C1 DESCRIPTION NOT AVAILABLE -SA Charcoal ADA Light Group ADLA Skid Plate Group ALN ARLA BAFP 130 Amp Alternator BCYP 495 Amp Battery CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission DRKP Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle ERH 4.0L I6 Power Tech Engine GFDA Rear Sliding Window GNCP Sun Visors w/Illum Vanity Mirrors GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZA Manual Remote Mirrors HAA Air Conditioning JAYA DO NOT USE - See JP, KA classes JGBP Digital Clock JHAA Var Intermittent Windshield Wipers JJAP Cigar Lighter KKSP STRIPE/BADGE/MOLDING/COLOR KWSP STRIPE/BADGE/MOLDING/COLOR K2BP STRIPE/BADGE/MOLDING/COLOR K27P Do Not Use LAJP Headlamps On Warning Chimes LBBP Courtesy Lamps LBDP Ash Tray Lamp LBEP LDAP Underhood Lamp LHDP Headlamp Off Time Delay MBJP Black Front Bumper MDA Front License Plate Bracket MHAP Black Windshield Moldings MMKP Lower Grille Surround-Painted Silver PW7 Bright White Clear Coat RAAC All Radio Equipped Vehicles RAFA AM/FM Cassette Radio RCDP 4 Speakers SBAP Power Steering TBBA Full Size Spare Tire TMWA Tires TZHP Michelin Brand Tires WJDP 15X7.0 Styled Steel Wheels WLYC All Steel Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z66P Left Front Group XV Z82P Right Front Spring Group XI 3V3A Customer Preferred Discount 5KNA Metro Cars of Detroit APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes CUMS Mini Floor Console DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMMS 3.07 Rear Axle Ratio GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass JCAS 85 MPH Primary Speedometer K3WS STRIPE/BADGE/MOLDING/COLOR LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MMCS Rear Door Solid Window Insert MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF2S 18.5 Gallon Fuel Tank QW7S Bright White Clear Coat SCES Steering Wheel SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 161S Zone 61-Atlanta Edited November 28, 2020 by Pete M Link to comment Share on other sites More sharing options...
sethrose2010 Posted November 27, 2020 Author Share Posted November 27, 2020 18” all terrain tires? That seems kinda weird. I didn’t know that was an option Also some of this stuff I’m not sure what it means but thanks. 👍🏻 Link to comment Share on other sites More sharing options...
89 MJ Posted November 27, 2020 Share Posted November 27, 2020 11 minutes ago, sethrose2010 said: 18” all terrain tires? That seems kinda weird. I didn’t know that was an option Also some of this stuff I’m not sure what it means but thanks. 👍🏻 Lots of these codes were reused by Chrysler, so this isn’t 100% accurate. Link to comment Share on other sites More sharing options...
sethrose2010 Posted November 27, 2020 Author Share Posted November 27, 2020 Ohh now that makes sense. Link to comment Share on other sites More sharing options...
Pete M Posted November 28, 2020 Share Posted November 28, 2020 5 hours ago, sethrose2010 said: Ohh now that makes sense. you don't have rack and pinion steering either. I've edited out the common wrong bits for ya. Link to comment Share on other sites More sharing options...
jdog Posted February 1, 2021 Share Posted February 1, 2021 Selling Dealer: LEON ROSSER JEEP-EAGLE Bessemer, AL Link to comment Share on other sites More sharing options...
