Novac 4wd shifter floor plate replacement
Many moon's ago I put in this Novak shifter when I upgraded to an AX 15 and lifted the truck. As a result I could not use the floor plate that came Stock and have had a big ole hole there since. Anyone else come up with a clever way to close up the outside from coming in?
The Novak
#SK2X Shifter Assembly
Is the shifter throw linear or does it have a gate? If it’s just a straight or linear throw I’d just grab a piece of aluminum from Home Depot and trim it to fit. Add some urethane sealer and some self tapping screws and your good to go. Make an opening for the shifter throw and put on a universal shifter boot (Novak probably has one they’ll give you off the shelf)
