Here is my current understanding of the early controller types.
Pre 87 had a single ecu connector?
The 4.0 XJ and MJ had the 32 and 24 way female harness connectors for the renix ecu from 1987 to 1990? I can source the harness connectors but the ecu 56 way is rather difficult to find. Does anyone have a bad renix ecu and/or harness?
I had good luck getting a complete harness from a junkyard on the internet, 120$ shipped, installed and the truck runs/works normally. Looked like ECUs were expensive though, hopefully someone has one.
i used car-part.com to find the harness
What are you looking for?  ECU and/or wiring harness?
I have a couple ECU: 87 ECU auto and 89/90 ECU auto.  (I have manual ECU, but not for sale.)
What do you have? It can be in terrible condition as long as the connectors are intact. I have some test pieces coming by the end of the day. If I can confirm they line up then I may have a working solution.
