LuisMj Posted September 25, 2020 Posted September 25, 2020 Simple enough but hard Time finding it I bought thisJeep a week ago, I need to know what parking cable to get to for the disk break conversion, disk breaks are on just dnt know where they came from would like to be able to buy just the rear cables that connect to the disk brake as the cable to the foot pedal is their
ghetdjc320 Posted September 25, 2020 Posted September 25, 2020 Can you send a picture of the back side of the brake backing plate? That we we can know what the connection should look like
ghetdjc320 Posted September 26, 2020 Posted September 26, 2020 Stock MJ e brake cables can be made to work with that setup (slight modification required) or you can run TJ cables as I believe that is the setup for them. Personally I’d just grab a set of universal cables in the correct length. It will come with various ends so you can get exactly what you need. I believe the TJ cables are a bit short if you have a long bed.
ghetdjc320 Posted September 26, 2020 Posted September 26, 2020 https://www.summitracing.com/parts/wil-330-9371 This would probably work just fine. There are many other options but I’m partial to Wilwood. Lokar makes a great set also that has more adapters in the kit also. Both of those kits are cut to length.
Dzimm Posted September 26, 2020 Posted September 26, 2020 Post up what you end up using, I'm in need of some as well for my red truck. What's the green wire running along there? Just curious.
AZJeff Posted September 26, 2020 Posted September 26, 2020 ZJ cables might work. Not guaranteed....just a suggestion.
