Kova92 Posted September 20, 2020 Posted September 20, 2020 On 11/2/2015 at 3:43 PM, 87MJTIM said: What year is the MJ? I ask because Renix (87 - 90) and HO (91 - 92) have different engine systems. This will help other diaguess (diagnose and guess) the problems. I have the Renix(1990) I've been having "misfiring" issues and a hard vibration under power. At first start it idles smooth-ish and then gets rougher. Fuel pressure is within limits, compression is within limits in all cylinders. I'm out of ideas. Any advice would be greatly appreciated
cruiser54 Posted September 20, 2020 Posted September 20, 2020 Ever replaced the cap, rotor, wires and spark plugs? Are all the vacuum lines on the engine intact? Ever checked to make sure the intake manifold bolts are tight?
MancheKid86 Posted September 20, 2020 Posted September 20, 2020 5 minutes ago, cruiser54 said: Ever replaced the cap, rotor, wires and spark plugs? Are all the vacuum lines on the engine intact? Ever checked to make sure the intake manifold bolts are tight? I agree with cap and rotor checking. your first post sounds like a worn out distributor bushing. pull your cap off distributor grab the rotor and wiggle it. if there is any play this could most definitely be the culprit.
JMO413 Posted September 20, 2020 Posted September 20, 2020 Have you cleaned up the wiring yet? Added and cleaned grounds? http://cruiser54.com Tips 1-5 are a must. There rest just help even more.
