1JTMG6413HT111069
ChrisDamnHejl
*A6 Seats - Vinyl High Back Bucket
-YY
3LR
APA MONOTONE PAINT PACKAGE
BCQ Battery - 750 Amp Maintenance Free
CBA BENCH SEAT - STRAIGHT BK
CGX Head Restraints-Outboard Seating, RR
CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ
DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER
ERB ENGINE - 4.0L I6 MPI GAS
GAC ALL WINDOWS - TINTED GLASS
HAA AIR CONDITIONING - FRONT
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JJA CIGAR LIGHTER - FRT COMP
KD8 STRIPE/BADGE/MOLDING/DELETE
LMA HALOGEN HEADLAMPS
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
PXH
QXH
SBA POWER STEERING
TBG SPARE TIRE - COMPACT
TBL TIRE CARRIER - INSIDE
WMC BASE WHEEL DRESS - UP (INCLS TRIM RING)
Build date 2/17/87
Body code TL61
5 minutes ago, ChrisDamnHejl said:
Eaglescout526, is this information for my Comanche? Did you get all that just from the VIN?? Thank you for researching and responding!! 😁
your actual build sheet would be longer, but a lot of info was lost before Chrysler computerized it all. :(  if you go look at a later VIN you'll see what I mean.
There's always a chance you can find your original still in the truck. :L:  it has been found under benches, behind the rear wall panel, behind a door card or even tucked up in the dash.  doesn't seem to be any rhyme or reason behind the various locations.  :dunno:
  • 4 months later...
