Muncher Posted August 29, 2020 Share Posted August 29, 2020 anyone got a hood scoop or vents In there hood i just got this one and wanna see if itl look cool or not. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 30, 2020 Share Posted August 30, 2020 Here’s mine. This is a Mach 1 hood scoop grafted in. It’s a pretty squared off scoop and looks good with the body lines. Link to comment Share on other sites More sharing options...
Pete M Posted August 31, 2020 Share Posted August 31, 2020 On 8/29/2020 at 3:26 PM, Muncher said: anyone got a hood scoop or vents In there hood i just got this one and wanna see if itl look cool or not. what are the dimension of it? Link to comment Share on other sites More sharing options...
Muncher Posted August 31, 2020 Author Share Posted August 31, 2020 Just now, Pete M said: what are the dimension of it? Don't have the exact dimensions but its off of a ford 7000 so its actually similar to a mach 1 hood but a little wider Link to comment Share on other sites More sharing options...
Pete M Posted August 31, 2020 Share Posted August 31, 2020 does it have thickness that protrudes into the engine bay? if so, how much of the hood bracing might need to be cut? Link to comment Share on other sites More sharing options...
Muncher Posted September 1, 2020 Author Share Posted September 1, 2020 On 8/31/2020 at 12:14 PM, Pete M said: does it have thickness that protrudes into the engine bay? if so, how much of the hood bracing might need to be cut? Nope it just bolts onto the hood Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 1, 2020 Share Posted September 1, 2020 The mach1 scoop takes a lot of work to get formed into the hood since it’s so long and the hood is slightly curved. Personally I recommend that you use a good seam sealer when bolting it on and stay away from cutting any hood bracing which is easy enough. Just don’t use any hard setting adhesive or filler because the hood flexes too much and will crack it. Link to comment Share on other sites More sharing options...
