1JCWC7566ET028672
500 MJ
Here is an interesting one. This VIN may not come up nicely in any database but I am sure there is a story for why that is the case. The VIN is found on a new tag that is affixed to the B-Pillar side of the driver's door, from Texas!?!? I will follow up with photos in the next post.
This is a 1984 Jeep Wagoneer that is currently at Wally's U-Pull It in Oshkosh WI. It is a Limited with the 2.8L and a dark red interior. Pretty well picked over but I might go back for the remaining chrome front end pieces...
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT
-ZZ
ADA LIGHT PACKAGE
ADB PROTECTION GROUP
AHL HEAVY DUTY INSUL PACKAGE
AJZ
AWH POWER EQUIPMENT GROUP
AWJ Visibility Group
BAC 75 AMP ALTERNATOR
BCQ Battery - 750 Amp Maintenance Free
CGW Air Bags - Front, Next Generation**
CGY Air Bag-Drvr Inflatable Knee-Bolster
CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ
CSB Spare Tire Cover
CUF FULL LENGTH FRONT CONSOLE
DGY Transmission - 4-Spd. Automatic,47RH
EFB ENGINE - 2.8L GM 6CYL
GAC ALL WINDOWS - TINTED GLASS
GFA ELECTRIC HEATED REAR WINDOW
GNI
GVB All Vehicles W/Power Mirrors
HAA AIR CONDITIONING - FRONT
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JAY Instrument Cluster w/Tach
JFH TACHOMETER - MECH
JGB ELECTRONIC DIGITAL CLOCK
JHA WINDSHIELD WIPERS - DELUXE
JHB REAR WIPER/WASHER
JJA CIGAR LIGHTER - FRT COMP
LAB TIME DELAY HEADLAMP SWITCH LIGHTING
LBB COURTESY LAMPS (BELOW PANEL)
LMA HALOGEN HEADLAMPS
MCA Front Bumper Guards
MCB REAR BUMPER GUARDS
MDA FRT LICENSE PLATE ATTACH REQUIRED
MPA BODY SIDE AND REAR WOODGRAIN FILM
MWA LUGGAGE RACK
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
NFA 20 GAL TANK - FRAME MTD
NHM AUTO SPEED CONTROL
NMB ENGINE COOLING - STANDARD DUTY
RAG RADIO - AM/FM/MX/MTR
SBA Power Steering
SCG 4 - SPOKE LEATHER STRG WHEEL - SPORTS TYEP
SDG SUSPENSION - 4-WHL INDEP. TOURING
SHA SWAY BAR - FRT
SUA
TILT STEERING COLUMB
Build date 10/31/83
Body code NO74
  • 1 year later...
41 minutes ago, The86manche said:
Wouldn't the wagoneer have had a different header panel?
Not the early ones. Early ones have the same header as ours but with one little detail changed. The Jeep nameplate in the front is smaller and shifted to the drivers side. I more want one for my XJ to make it a base waggy.
The more you know. Lol
I did not know that. Cool little detail.
