CaptainPatchy Posted August 24, 2020 Share Posted August 24, 2020 Okay, so yesterday when I was moving things over to our new home I noticed a very strong gas smell in the new garage after I backed in. I chalked it up to maybe a bad cat, or just being a very hot day and didn't think anything of it. Noticed the same thing this morning after the first load, and when I was looking around, I saw a small puddle under the airbox area of the truck, popped the hood and saw this: Didn't think it was too bad, but suspected maybe something wrong with the connector so I relieved the rail pressure and pulled them both off to inspect. Looked fine so I reconnected them, and went to prime the pump. That's when I saw this: Okay, so that's not a bad O-ring, but a needle hole in the actual hose. What do I do to replace or repair this? I looked online and can't find replacement hoses in stock anywhere, even dealer-resellers. Is there an option to just bypass the quick connects altogether so I could run rubber fuel line from an auto parts store? Link to comment Share on other sites More sharing options...
Dzimm Posted August 24, 2020 Share Posted August 24, 2020 You can get the quick connects from the HELP rack at the auto parts store. On mine, I cut that plastic line off back at the metal fuel line and attached the rubber there and a new quick connect fitting. It takes like 10" of rubber hose to replace the plastic section. If you leave a little bit of the plastic line on the metal line, it will act like a flare to help seal and hold the rubber fuel line to the metal line. The metal line doesn't have a flare there so it can be tricky to keep the rubber on there. Just be sure to use hose rated for fuel injection systems. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted August 24, 2020 Share Posted August 24, 2020 You can buy a new end through Dorman etc , and also a barb to connect the plastic hose together . Dorman also sells compression fittings that will hold the plastic line together. Link to comment Share on other sites More sharing options...
