Phillip Gwin Posted August 11, 2020 Posted August 11, 2020 Can you tell me where I can find the VIN plates on my 90?
Rotten Ralphy Posted August 11, 2020 Posted August 11, 2020 I can't speak for a '90. My '88's are located on the driver's door, the radiator support, and also has one in the glove box.Sent from my iPhone using Tapatalk
boxyjeep Posted August 11, 2020 Posted August 11, 2020 What I've seen on my '88: there is one on the dashboard, a steel tag right inside the hood on the drivers side fender/cowl, the last few digits are stamped in the front crossmember. There is likely something on the frame and bed somewhere in the rear, as well as a few other spots. How are you planning to do the swap?
eaglescout526 Posted August 11, 2020 Posted August 11, 2020 I have seen a VIN plate on the crossmember under the radiator (or by) in an 89 4.0L 2 door XJ.
Pete M Posted August 12, 2020 Posted August 12, 2020 all I know is I've been trying to find a vin tag in the back half of an MJ (i.e. my trailer) for a couple years now and failed.
