Eagle Posted August 9, 2020 Posted August 9, 2020 Post split off, because it was posted to a ten-year old thread about a different topic.
Pete M Posted August 9, 2020 Posted August 9, 2020 15 hours ago, Comanche1 said: Will a cj knob fit my 4 speed? with a drill and some epoxy, most anything can work.
Pete M Posted August 9, 2020 Posted August 9, 2020 2 hours ago, Comanche1 said: Tell me about relay harness please for the headlights? it's a simple harness that plugs in and uses a relay to power the lights. this means more voltage gets to the lights (brighter!), and less wattage is coursing through the poor old headlight switch (meaning less chance of a fire).
JustEmptyEveryPocket Posted August 9, 2020 Posted August 9, 2020 1 hour ago, Comanche1 said: Tell me about relay harness please Time to learn how to google. That will return alot more information for you. Here's how I recommend you go about it: Go to google.com type in "site:comancheclub.com relay harness" and start reading the threads that show up. Vary your search string to get different results. For example, you might try headlight upgrade instead of relay harness. That should give you more threads where you can do more learning. The string site:comancheclub.com will limit all results to this domain. You can vary that part as well if you want to get results from say NAXJA or something else. Finally, don't forget about a Google Image search. If you want to see what a CJ shifter knob looks like and how people have adapted them, that would be a great way to approach it. In general I would recommend you do your own research first, then start a thread to ask follow-up questions. More positive interactions that way. From my experience, 90% of questions I have had have already been asked multiple times and can be found in threads with a bit of looking. Sometimes those threads even include the resolution! Good luck, and happy reading!
