Jongat88 Posted July 26, 2020 Posted July 26, 2020 I thought I saw some where on here that someone doing the swap from a 2.5 to a 4.0 automatic that a rear driveling out of a 1997 dodge Durango or Dakota would work. I know its 45 1/2 inches from saddle to saddle is this true. And if you know please put the correct year, make and model of truck am I looking with a driveline left in it. Thanks
Eagle Posted July 26, 2020 Posted July 26, 2020 Why do you need to change the rear axle when you change the engine?
mjeff87 Posted July 27, 2020 Posted July 27, 2020 Jon and I have been PM'ing about this. Yes, he's talking about the rear driveshaft. He's up in Alaska, doesn't have many options (that aren't quite expensive...)
Eagle Posted July 27, 2020 Posted July 27, 2020 Pardon my confusion. "Driveline" typically refers to everything between the engine and the driving wheels.
mjeff87 Posted July 29, 2020 Posted July 29, 2020 Jon, I did some interneting....wow it's kind of hard finding good info on Dakota rear driveshafts. As usual, there's a big length size variation depending on driveline configuration, wheelbase, etc. The shortest one I could find mentioned anywhere was 63" for a "standard" cab, 4WD with manual transmission. Some Dakotas and Ram p/u's also came with 2 piece rear shafts with a carrier bearing in the center. So I don't think a Dakota shaft would work for you unless you had a shop cut it down. Again, that's all from Googling, so FWIW. You might try a Dakota to see if they are any shorter (??) Jeff
