Patrick_Rash Posted July 4, 2020 Share Posted July 4, 2020 With a build date of 8/1/85, is the firewall far back enough to do a I6 conversion pretty easily? Link to comment Share on other sites More sharing options...
omega_rugal Posted July 4, 2020 Share Posted July 4, 2020 we don't know, you tell us... some pics? Link to comment Share on other sites More sharing options...
Pete M Posted July 4, 2020 Share Posted July 4, 2020 I seriously doubt it, but if you can snap a pic of the firewall at the back of the engine we should be able to tell you. also, it doesn't really matter one way or the other since the fix is just a couple whacks with a big hammer. Link to comment Share on other sites More sharing options...
AMC86Kid Posted July 4, 2020 Share Posted July 4, 2020 It will fit as far as how easy it is that’s all gonna depend on how good of a mechanic you are Link to comment Share on other sites More sharing options...
JimB Posted July 5, 2020 Share Posted July 5, 2020 My 1986 came with a 4cyl. I had to knock where the firewall curves into the transmission tunnel, about where the temp sensor is located at the back of the head. In about an inch or two. Also the support for holding the radiator needs to be swapped. I had a 1987 XJ that I used for parts and comparison. Link to comment Share on other sites More sharing options...
omega_rugal Posted July 6, 2020 Share Posted July 6, 2020 On 7/4/2020 at 7:49 PM, JimB said: Also the support for holding the radiator needs to be swapped. I had a 1987 XJ that I used for parts and comparison. why not keep the radiator? you think it may not be adecuate? from what y have seen it´s a lot of modding to fit the large 4.0 one Link to comment Share on other sites More sharing options...
JimB Posted July 6, 2020 Share Posted July 6, 2020 I know that the fan on the 4.0 sits off to the passenger side. Not directly in the middle. I had a 1987 cherokee for parts. So I decided to drill out the spot welds and reweld new parts. You might be able to use an electric fan and do away with the mechanical fan all together. I also put the auto trans from the 87 into the 86. I had to have the driveshaft shortened. Other than that it was not that big of a job. Link to comment Share on other sites More sharing options...
