early comanche owner Posted June 28, 2020 Share Posted June 28, 2020 do you know what seats would be a direct swap for my 1990 comanche buckets? would grand cherokee or cherokee front seats work? Link to comment Share on other sites More sharing options...
89 MJ Posted June 28, 2020 Share Posted June 28, 2020 Cherokee will bolt in as long as yup use the Comanche brackets. @krustyballer16 Makes new brackets. Link to comment Share on other sites More sharing options...
Pete M Posted June 28, 2020 Share Posted June 28, 2020 define "direct"? if you're looking for no efforts short of unbolting it from the floor, only MJ seats will do that. If you're looking for seats that look factory and tilt forward so you can access behind them, 2door 84-94 XJ seats do that (avoiding the curved slider ones because those raise you up a couple inches over stock). you'll still need to swap floor brackets, but that's pretty easy. If you're simply looking for something comfortable that fits the space and you don't mind fabbing up an adapter made from 1x1 tube between the new seats and the old floor brackets (frequently this only entails cutting to length and drilling holes for bolts), then the junkyard is your oyster. wander around until you find a set that your butt likes and get them. most any bucket seat will fit. and 2-door car seats usually tilt forward. Link to comment Share on other sites More sharing options...
