1987 Jeep Comanche 4x4 4.0 5 speed manual transmission Shortbed.  Has 147,000 miles on it.  Running and driving hopefully will be for a while.  Indianapolis Indiana area.  Would like to know how it came from the factory, I was told that it has a dana 44 axle and the metric ton package.
Build Date JL61
Body Model 1/11/87
*A6 Seats - Vinyl High Back Bucket
-YY
3LQ
APA MONOTONE PAINT PACKAGE
CBA BENCH SEAT - STRAIGHT BK
CGX Head Restraints-Outboard Seating, RR
DDQ Transmission - 5-Speed Manual
DMR 3.07 Axle Ratio
DSA LIMITED SLIP DIFFERENTIAL
ERB ENGINE - 4.0L I6 MPI GAS
GAC ALL WINDOWS - TINTED GLASS
GFD SLIDING RR WINDOW
GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JHA WINDSHIELD WIPERS - DELUXE
JJA CIGAR LIGHTER - FRT COMP
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LMA HALOGEN HEADLAMPS
MBJ Bumper - Front, Black
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAE EMISS CONTROL TESTING &&&& LABEL
NMB ENGINE COOLING - STANDARD DUTY
PXH
QXH
SBA POWER STEERING
TBB CONVENTIONAL SPARE TIRE
TBL TIRE CARRIER - INSIDE
WMC BASE WHEEL DRESS - UP (INCLS TRIM RING)
metric ton MJs were all longbeds, but shortbeds could still get the d44 separate from the MT package. :L:
also, the build list for older trucks is incomplete because a lot of info was lost before the transition into Chrysler's computers. :(  but you may be able to find your paper copy.  it could be stuffed i the bottom of a seat, or behind a door panel, or other places.  :D
a photo of the rear axle will tell us if it's a 44 or a 35.  the 44 has a stop sign octagon kinda shape to it.  the 35 is an oval blob.
  • 7 months later...
