Park13 Posted May 21, 2020 Share Posted May 21, 2020 Is there a place that sells the U-bolt perch and with shock mount all in one? Getting ready to swap, and I understand the Chrysler 8.25 is 3” tube diameter, while the stock metric ton Dana 44 is 2 3/4” thanks!! Link to comment Share on other sites More sharing options...
neohic Posted May 22, 2020 Share Posted May 22, 2020 You should be able to open up the slots in the plates with a die grinder to allow the bigger u-bolt. Nothing fancy there. Curious us why you’re dumping the 44 though. Link to comment Share on other sites More sharing options...
Dzimm Posted May 22, 2020 Share Posted May 22, 2020 The u-bolts for a C8.25 still fit into the slots on the factory spring plate. I've done it with both styles of spring plate and it fit both of them fine. Put the u-bolt into the plate outside the truck the first time and it will make it easier to install once it's in the truck, it's tight the first time the u-bolt goes into the plate but it does fit without modification. Link to comment Share on other sites More sharing options...
Park13 Posted May 22, 2020 Author Share Posted May 22, 2020 4 hours ago, neohic said: You should be able to open up the slots in the plates with a die grinder to allow the bigger u-bolt. Nothing fancy there. Curious us why you’re dumping the 44 though. I got a really good deal on 4.10 Gear setup with 1 ton steering on Dana 30 / 8.25 2 hours ago, Dzimm said: The u-bolts for a C8.25 still fit into the slots on the factory spring plate. I've done it with both styles of spring plate and it fit both of them fine. Put the u-bolt into the plate outside the truck the first time and it will make it easier to install once it's in the truck, it's tight the first time the u-bolt goes into the plate but it does fit without modification. Much appreciated!! Link to comment Share on other sites More sharing options...
