It started with a Harmonic Balancer....
The timing cover ended up being cracked. I swapped that out, loosing a bolt in the process. Got the water pump back on and noticed this. The crude must have been holding it together because it has risen from the grime mark. Any thoughts.
89' 2.5L with a 5-speed. I bought this to get me to the river and hardware store for projects. This is quickly becoming the project. Had it for two months during the shelter in place and have been doing little things to make it road safe.
That is entirely possible, but I wouldn't worry about it too much like I said. Its just a shock absorber that AMC put there for whatever reason. I know the engine can give off harsh vibrations with sputtering or leaving it in gear on deceleration but that's about all I can think of for that shock.
21 minutes ago, fiatslug87 said:
Yes, I know that. It's just nice to get a little info, not just "what's wrong here."
Yeah I guess it was one of those thing he had that was just blatantly obvious to me but may not have been for others.
2 hours ago, eaglescout526 said:
That shock is hard to find/irreplaceable. Just keep it and clean all the gunk off of it and it is good to go. Looks like it could use a degrease bath.
Agreed with the suggestion to clean the gunk off.   The oil on the rubber bushings for the shock will cause it to deteriorate.
Time to get some foamy engine cleaner and the hose, and go to work on the engine compartment.
