AMC86Kid Posted May 20, 2020 Posted May 20, 2020 I was wondering where the three thin wires that are connected to the turn key ignition switch go to ?
AMC86Kid Posted May 20, 2020 Author Posted May 20, 2020 The purple wire goes to pin 14 behind the instrument cluster (water temp gauge)
AMC86Kid Posted May 20, 2020 Author Posted May 20, 2020 But where does the gray with red line and black with white line go to and what are they used for ??
boxyjeep Posted May 20, 2020 Posted May 20, 2020 Refer to the wiring diagrams in the '88 electrical manual. You should be able to find it online if you search.
Eagle Posted May 20, 2020 Posted May 20, 2020 5 hours ago, Chargum85 said: Refer to the wiring diagrams in the '88 electrical manual. You should be able to find it online if you search. That's a possibility, but he has an '86 and thgere's no guarantee that the wire colors are the same.
eaglescout526 Posted May 20, 2020 Posted May 20, 2020 I helped in out with finding all those wires except two, the grey and purple. Could not find either of them in my 86 diagrams. But found out that the black one goes to the ebrake switch up to the light.
