Hello, Looking to see if someone knows of reproduction cab vent rubber flaps on the b pillar. Just had my truck painted (took 6 months) and see that the flaps are gone on one side. I had pulled off the plastic outer cab pieces before I took it in the body shop. I may try to make them out of a motorcycle rim bad that covers the spoke nipples if some one doesn't make them. Give me your thoughts of maybe what else will substitute for these rubbers. Thanks
Hi again, we;; I was hoping someone would respond about me doing this cab vent with rim bands as good or bad so I did it anyway. Here is how it turned out and just hope that the rubber material holds up for a few years. original flap is the bottom. Rim band was slightly thicker material, don't think it will affect the way these vents work though still very flexible. Paul
