Floor Support name/number
Does anyone know the name or the part number of the small floor suport connecting from the inner rocker to the middle frame. I believe it's the same on cherokees as well but was replaced with that box tube looking one that their seat mounts to. Any help would be greatly apreciated!
I call it, depending on how official I feel, either the "sideways triangle floor thing" or the "transverse floor brace"
It's spot welded to the uniframe rail through the floor pan around the edge in several places. I strongly doubt you can get a new one, but you should look under it if you haven't to see if there is rust hiding underneath.
While on the subject, I'm pretty sure all the Comanche specific parts are discotinued, but is the trans tunnel the same as an XJ? If so, are reproductions available? All I can find is XJ floor pan sections
