Help!!!
31 minutes ago, Aidan said:
I bought the crown one as recommended by Ohm, I had to order a second one so I really hope it's the right one emoji23.png they did look different if that helps
Sent from my moto e5 play using Tapatalk
Crown is probably second best after a genuine Mopar unit. Still aftermarket, but a friend of a friend's dog once told me that Crown conforms to the Mopar specifications for some parts. :dunno:
Had a huge oil leak suddenly appear on the 88 XJ - had to move it out of the way of the boat and decided to drive it to pick some fuel for the kicker, got back and parked it - 1/2 hr later noticed a dinner plate sized oil spot - WTF?
Turned out it was the Oil pressure sensor (have full gauges in the XJ) - see pic, the plastic body separated (you can see the o-ring) and oil was spewing out when it was running - and big surprise, the gauge was not working..
So ordered this one off of Amazon:  Standard Motor Products PS315 Oil Pressure Sender
$21 shipped and works fine - but definitely does not look like the big metal one in the MJ - figure that one might be original?
