SeasToSwamps Posted April 26, 2020 Share Posted April 26, 2020 Hey y’all me again, On to the next step. I’m pulling the engine for a rebuild and I just wanted to know how many bolts I should be looking for for disconnect. I got the visible ones but I don’t want to start pulling and find out I missed some. Also any tips for the disconnect/ hard to reach bolts if I missed any? Link to comment Share on other sites More sharing options...
jdog Posted April 26, 2020 Share Posted April 26, 2020 did you get the top two torx, if not a really long (like 3ft) extension and a wobble Link to comment Share on other sites More sharing options...
SeasToSwamps Posted April 26, 2020 Author Share Posted April 26, 2020 No I didn't thanks, How many regular bolts should I be looking for? Link to comment Share on other sites More sharing options...
jdog Posted April 26, 2020 Share Posted April 26, 2020 I believe its four not including those two torx, the starter and the inspection cover Link to comment Share on other sites More sharing options...
strictlyxjs Posted April 26, 2020 Share Posted April 26, 2020 Three 13mm on front side (engine side of dust shield each side top and one center buttom) Two 18mm nut bolt combos bottom of bellhousing Two e12 torx top of trans Two 16mm each side of trans. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 27, 2020 Share Posted April 27, 2020 18 hours ago, jdog said: did you get the top two torx, if not a really long (like 3ft) extension and a wobble Loosen/remove these BEFORE any others!!!!!! Link to comment Share on other sites More sharing options...
