WahooSteeler Posted April 12, 2020 Share Posted April 12, 2020 Looking for the bolt size and thread pitch for the bolt that holds the bottom of the quarter window at the bottom of the window track. It's a 10mm head but not sure the size and thread. Had to take mine out to do some door and window work and it was stripped. Thanks for any help Link to comment Share on other sites More sharing options...
Eagle Posted April 12, 2020 Share Posted April 12, 2020 Quarter window? MJs don't have quarter windows. Are you talking about the triangular front side window? Link to comment Share on other sites More sharing options...
WahooSteeler Posted April 12, 2020 Author Share Posted April 12, 2020 11 minutes ago, Eagle said: Quarter window? MJs don't have quarter windows. Are you talking about the triangular front side window? Yes......quarter, third, pizza slice....whatever it is. Mine are fixed so I couldn't call them "smoker windows" like a lot of people do LOL. Link to comment Share on other sites More sharing options...
Minuit Posted April 12, 2020 Share Posted April 12, 2020 While I can't tell you for sure right this minute, the safe answer for a 10mm head is M6x1.0, and that sounds about right to me based on the way that bolt has looked when I had it removed. I can't check for you right this minute, but if someone doesn't have a definite answer for you I can always go out to my truck and check it for you... not much else for me to do right now Link to comment Share on other sites More sharing options...
WahooSteeler Posted April 12, 2020 Author Share Posted April 12, 2020 36 minutes ago, Minuit said: While I can't tell you for sure right this minute, the safe answer for a 10mm head is M6x1.0, and that sounds about right to me based on the way that bolt has looked when I had it removed. I can't check for you right this minute, but if someone doesn't have a definite answer for you I can always go out to my truck and check it for you... not much else for me to do right now Jeremy, thanks for the info and no need to go through the trouble of checking your truck. I happen to have some M6 bolts as that is what I used to mount my new window regulator. I'll check that tomorrow! Link to comment Share on other sites More sharing options...
Pete M Posted April 12, 2020 Share Posted April 12, 2020 when we confirm it, if someone could update the "bolt size" thread in the link in my signature that'd be awesome. Link to comment Share on other sites More sharing options...
