1J7FT36L3KL434559
lcoutback
Year / Model:  1989 Pioneer
Original stats:  4.0 / AW4 / 2x4 / D35 / SWB
Build Date:        9/88
Current Location: Forest Grove, Oregon
Status: Just a weekend cruiser, desert explorer.
Notes: I rescued Papa Smurf from central Oregon.  The PO thought it was about to blow up because it leaked oil and overheated.  Funny how a new oil pressure sending unit and antifreeze fixed those little issues!
Since I've had it I've converted it to 4x4.  Still 4.0 with about 250K miles, AW4 column shift with a fresh built stock NP231 with a SYE and a 8.8" rear differential.  Geared with 4:10's running 33" tires to keep the speedometer happy.  Nothing too special, but I've swapped in a full instrument cluster, Dynamat the floor, door skins, roof and behind the seat.  All the interior lights work, including the lights I snagged from my wrecked XJ that light up the floor board.  No Rust, very straight with a fully functioning tailgate latch!  Just a clean and solid example of simple, like me...
Current owner:  Bob Pardee, AKA LCO20170604_084713.jpg.9c7fe43a422a7f2b45f344c35e24c0fc.jpgutback
*E1 Cloth Bench Seat
-SA Charcoal
172 Zone 72-Portland
1AA U.S. Dealer Retail
5AM Largo Tracking
5KM AMES Department Stores
ALM
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Open
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHT  Shift-on-the-Fly,P/Time T/Case
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HCD Do Not Use - See HCA
JAA Instrument Panel
JAZ DO NOT USE - See JP, KA classes
JBD BEZEL-I/PANEL CLUSTER - BRIGHT
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
JKB
K2X STRIPE/BADGE/MOLDING/COLOR
K3B STRIPE/BADGE/MOLDING/COLOR
KKE
LAF Seat Belt Alert-Driver Seat only
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFG Body Color Headlamp Bezels
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF2 18.5 Gallon Fuel Tank
PB3 Intense Blue Pearl Coat
QB3 Intense Blue Pearl Coat
RAA All Radio Equipped Vehicles
RAB AM/FM Radio
RCD 4 Speakers
SBA Power  Steering
SCE  Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TPF P205/75R15 BSW All Season Tires
WJD 15X7.0 Styled Steel Wheels
XBS Pickup Box
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
YGG 9 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z58 Left Front Spring Group Viii
Z78 Right Front Spring Group VIII
Build date 9/18/88
Body code TM61
  • 1 year later...
