LT1 and 4L60E
On 5/6/2020 at 10:50 PM, Jomanche said:
anyone got a nice 2WD?   might just drop a LS in it and lower it this time
That'd be interesting.  Novak mounts require a lift, so you might need to make your own mounts (unless you do the custom A-Arm and front crossmember route like @Awinski
  • 3 months later...
Pete
Had to send them pics as they were going to look into it in the mean time and do a little research to see what other solutions there maybe. I didnt want to have my guy beat on the frame rails as we've all seen in Youtube videos.
So I'm patiently waiting to hear back from them.
I also looked thru some of the epic build as you've suggested and nothing really popped out at me about other options to use. One guy tried a few sets to no avail then eventually modified a cheap set.
  • 9 months later...
How did you hook up your shifter linkage?
I'm in the middle of my swap, and am looking for a shifter cable solution, any help with what you're running could help.
To help anyone looking...
I'm swapping a lc9 5.3/ 4l60E combo into an 89 2wd mj, with novak mounts, and I do not need to lift it for my steering to clear.
have you started your build thread yet?  you should do that :L:
  • 10 months later...
UPDATE:
Project has been at a stand still…. of course due to COVID and other issues.
The manch is now at another garage with a bed full of parts waiting on the time for someone to get to it. The main hold up now is when the old engine was taken out so was the engine bay harness. The harness / fuse box that I got out of a similar year XJ had different connectors on the ends.
I need a harness and fuse box…..
So Pete M and others my question is this…. Is there an after market harness and fuse box that is plug and play with the LT1 and MJ? Any help getting this jump started and going again would be greatly appreciated.
