70barracuda Posted March 13, 2020 Posted March 13, 2020 having trouble getting the yoke to slide on the output shaft of my trans. itll go on about 1.5 inches and then just stop. I have it greased. I gave it a tap with a rubber hammer, not hard, and it didnt really move. It also locked up the trans so I couldnt spin it. Tapped it back off and couldnt really see where it was contacting. Not sure if the 2wd or 4wd jokes are different.
mjeff87 Posted March 14, 2020 Posted March 14, 2020 I know from experience that AX5 trannies 2WD/4WD output shafts are different splines....23 (?) and 27 spline if I remember correctly. I'd imagine the AX15 would be the same too.
Big Dan Posted March 14, 2020 Posted March 14, 2020 They are different. For ax15 2wd, you need Spicer 2-3-10391x Sent from my Pixel 2 XL using Tapatalk
70barracuda Posted March 14, 2020 Author Posted March 14, 2020 Oof 80 bucks for a yoke. And it is 27 spline I counted. It goes on so spline number is good but it's almost like it's too thick to fit all the way
Big Dan Posted March 14, 2020 Posted March 14, 2020 You probably have a yoke for a th400. It's point 01 inches thicker.I had the same issue.Shop around, on ebay. I found mine for 55, I believe. Sent from my Pixel 2 XL using Tapatalk
70barracuda Posted March 14, 2020 Author Posted March 14, 2020 Just found one for 50 bucks on eBay. Everywhere else wanted like 85+
SatiricalHen Posted March 16, 2020 Posted March 16, 2020 Is the AW4 2wd yoke the same as the AX-15 2wd yoke? When I did my BA10 to AX-15 swap I used the yoke from a 2wd AW4 and it seems to work fine. I have a 2wd AX-15 with the yoke sitting in my shed if they’re different and should swap them. I haven’t noticed any weird stuff, but always best to have the correct part even if what you have seems to work. Sent from my iPhone using Tapatalk
NateD Posted August 4, 2023 Posted August 4, 2023 On 3/13/2020 at 10:02 PM, Big Dan said: They are different. For ax15 2wd, you need Spicer 2-3-10391x Sent from my Pixel 2 XL using Tapatalk Sorry to revive an old thread, but using that spicer slip yoke is there a different size output shaft seal I have to use? I tried it and it leaks like crazy. Trans is from a 96 Dakota.
