Chase The Hero Posted October 4, 2007 Share Posted October 4, 2007 hey anyone out there know how much u can lift an MJ befotr having to mod it? jus got truck 2 weeks ago. Link to comment Share on other sites More sharing options...
Bacon Posted October 4, 2007 Share Posted October 4, 2007 huh? lifting it IS modifying it. you're gonna have to be more specific. but the general rule is, the more you lift the suspension, the more problems you're gonna run into with other things like driveline, steering, brakelines.... Link to comment Share on other sites More sharing options...
89eliminator Posted October 4, 2007 Share Posted October 4, 2007 you can put in a 2-3 inch lift before you have to get different lower control arms. Link to comment Share on other sites More sharing options...
feerocknok Posted October 4, 2007 Share Posted October 4, 2007 I feel anything over 2" should come with new lower control arms. Link to comment Share on other sites More sharing options...
MJ'87 Posted October 4, 2007 Share Posted October 4, 2007 i put a 5" lift for rocky-road.com on my '87 mj. its fine without the longer lower control arms, but i can't get too off camber or go over big bumps without my front tires rubbing flairs. id like to get em, but money is an issue. Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 4, 2007 Share Posted October 4, 2007 chase... 2" budget lift (not reccomended but cheap) 3" with coil pack.. thise are basically your options without anything major. go over that and you worry about axle and steering issues. Link to comment Share on other sites More sharing options...
Chase The Hero Posted October 5, 2007 Author Share Posted October 5, 2007 ok. thanks yall this is much appreciated. how much would a budjet lift cost? I'm kinda on a low budjet so the more bang for the buck the better. :D Link to comment Share on other sites More sharing options...
feerocknok Posted October 5, 2007 Share Posted October 5, 2007 i put a 5" lift for rocky-road.com on my '87 mj. its fine without the longer lower control arms, but i can't get too off camber or go over big bumps without my front tires rubbing flairs. id like to get em, but money is an issue. At 5", I needed new lowers, a track bar, and could use uppers. My stock lowers contacted the shock mount at ride height with 5" of lift, making it so I had no down travel. Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 5, 2007 Share Posted October 5, 2007 ok. thanks yall this is much appreciated. how much would a budjet lift cost? I'm kinda on a low budjet so the more bang for the buck the better. :D here its nothing special but should lift you a little the rear may not be 2'' but the rear sits about 3/4'' higher so it should even it out Ebay lift kit Link to comment Share on other sites More sharing options...
Chase The Hero Posted October 5, 2007 Author Share Posted October 5, 2007 question, do XJ AALs fit MJs? :dunno: Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 5, 2007 Share Posted October 5, 2007 yes they do but they don't add as much lift like less than one inch. now the only thing with AAL is that they make for a harder ride as the AAL is lifting up the other leafs so take that into consideration. i guess you could always run tires low Link to comment Share on other sites More sharing options...
