Fuel rail inlet and return line seals 88 Comanche 4.0
Howdy. I’m needing info on my fuel line seals. On the fuel rail I have two lines with quick disconnects. When I disconnected them ,two small o rings and what appears to be A spacer fell out .the O rings  are in bad shape and I want to replace them but I can’t find any information on what size they were . Do they make a kit with the rings and spacer? What are my options on repairing this?
Edited by Comanche man Don
Added more info
What year MJ and engine do you have? Add it to your signature.
Renix and HO are different, 2.5L I think are the same as 4.0L Renix..
 Renix 5/16 line  https://www.morris4x4center.com/fuel-oil-cooler-line-repair-kit-83502745.html
 HO 3/8 line  https://www.morris4x4center.com/fuel-oil-cooler-line-repair-kit-83504447.html
And it goes o-ring/spacer/o-ring
Fuel disconnects
Quick disconnect part numbers
The Napa part numbers for just o-rings *is:
Napa 730-5018 3/8 Viton individual o-rings
Napa 730-5017 5/16 Viton individual o-rings
*Remember to re-use your old spacer between the 2 new o-rings!!
Napa CRB 212305 fuel line repair kit 5/16
Dorman 800-750 trans line repair kit 3/8
Mopar repair kits:
83502745 fuel line repair kit 5/16
83504447 fuel line/Trans line repair kit 3/8
