1JTMR65T9HT086995
Skibrew
*W7 Cloth Lo-Back Bckt/Red Accent Seats
-H9
ADA LIGHT PACKAGE
ADL SKID PLATE GROUP
AGL PLYMOUTH SPRING SPECIAL PACKAGE
AHL HEAVY DUTY INSUL PACKAGE
AHY Hybrid Electric Vehicle 15 KW Group
APA MONOTONE PAINT PACKAGE
BCQ Battery - 750 Amp Maintenance Free
CAC BUCKET SEAT - LO BK
CGW Air Bags - Front, Next Generation**
CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ
CUF FULL LENGTH FRONT CONSOLE
DGQ TRANSMISSION-5SPD AUTOMATIC 5-45RFE
DMR 3.42 Axle Ratio
ERB ENGINE - 4.0L I6 MPI GAS
GAC ALL WINDOWS - TINTED GLASS
GEC Window - Left Side, Front, Sliding
GFD SLIDING RR WINDOW
GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME
HAA AIR CONDITIONING - FRONT
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JAY Instrument Cluster w/Tach
JGB Clock - Digital
JJA CIGAR LIGHTER - FRT COMP
K60 BODY SIDE MLDGS - VINYL
LBB COURTESY LAMPS (BELOW PANEL)
LDA UNDERHOOD COMPT LAMP
LMA HALOGEN HEADLAMPS
LNJ Fog Lamps
LPE EXTERIOR CARGO LIGHT
MBF REAR BUMPER - STEP TYPE (BRIGHT)
MCA FRONT BUMPER GUARDS
MCB REAR BUMPER GUARDS
MD8 Delete Front License Plate Bracket
MFD BRIGHT GRILLE - TYPE I
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
NFA TANK - 20 GAL FUEL
NHB HVY DTY/AUX TRANS OIL COOLER
NMB ENGINE COOLING - STANDARD DUTY
PA2 SILVER MET CLEAR CT PRIMARY PAINT - FA2
QA2 SILVER MET CLR CT SECONDARY PAINT - FA2
RAB Radio - AM/FM
SBA POWER STEERING
SCG LEATHER STRG WHEEL - EURO/SPORT TYPE
TBB CONVENTIONAL SPARE TIRE
TBL TIRE CARRIER - INSIDE
WJN 15" Aluminum Wheels
Build date 1/13/87
Body code JP62
36 minutes ago, Skibrew said:
Thanks, much appreciated.
be sure to take the list witha  grain of salt.  I see a lot of reused codes in your printout.  Pretty sure you don't have a hybrid or a 5spd or a 3.42 axle gear. :D
  • 11 months later...
