Muncher Posted February 20, 2020 Share Posted February 20, 2020 So I'm still trying to get a comanche but there's no really nice ones around me except one. The only problem with that one is that it's not a 4x4. How hard is a 4x4 and what do u need for it? Link to comment Share on other sites More sharing options...
Muncher Posted February 20, 2020 Author Share Posted February 20, 2020 It is also a column shift so I'm not sure if that would affect anything Link to comment Share on other sites More sharing options...
Pete M Posted February 20, 2020 Share Posted February 20, 2020 you'll need the basics. an appropriately geared front axle, a front driveshaft, a shorter rear driveshaft, 4wd trans, t-case, t-case shifter linkage and brackets. frequently it's cheaper to buy a whole XJ to get what you need. (you'll still need a rear shaft because the XJ is too short) now's the time to think about lift, re-gearing, etc. since you're taking everything apart anyway. Link to comment Share on other sites More sharing options...
jdog Posted February 20, 2020 Share Posted February 20, 2020 check the master project list in Petes signature, but yea not terrible to change and shouldn't be an issue with a column shift Link to comment Share on other sites More sharing options...
Muncher Posted February 20, 2020 Author Share Posted February 20, 2020 15 hours ago, jdog said: check the master project list in Petes signature, but yea not terrible to change and shouldn't be an issue with a column shift That's what I would hope cause I think I'd prefer a column shifter Link to comment Share on other sites More sharing options...
Muncher Posted February 20, 2020 Author Share Posted February 20, 2020 16 hours ago, Pete M said: you'll need the basics. an appropriately geared front axle, a front driveshaft, a shorter rear driveshaft, 4wd trans, t-case, t-case shifter linkage and brackets. frequently it's cheaper to buy a whole XJ to get what you need. (you'll still need a rear shaft because the XJ is too short) now's the time to think about lift, re-gearing, etc. since you're taking everything apart anyway. I see a lot about the ax15 transmission swap to would that be better to do? Link to comment Share on other sites More sharing options...
Pete M Posted February 20, 2020 Share Posted February 20, 2020 that brings up the manual transmission vs automatic discussion. only you can answer to what you would prefer to drive. The AX-15 is the upgrade to the older Peugeot (ba-10/5) manual trans. If you have an auto, that'd be the AW-4 and it's a fine transmission as-is. Link to comment Share on other sites More sharing options...
