mvusse Posted February 14, 2020 Posted February 14, 2020 Ignoring the extra supports that Cherokees don't have, the transmission crossmember is held on to the uniframe rail with two bolts and two studs. Does anybody know if these studs are removeable, or if they are welded in?
jdog Posted February 14, 2020 Posted February 14, 2020 They are removable and are just screwed in Stock 1988 swb 4.0 ax15 np 231.
Warren Mohler Posted February 14, 2020 Posted February 14, 2020 One of mine turned out last time I replaced clutch
DesertRat1991 Posted February 14, 2020 Posted February 14, 2020 38 minutes ago, mvusse said: Ignoring the extra supports that Cherokees don't have, the transmission crossmember is held on to the uniframe rail with two bolts and two studs. Does anybody know if these studs are removeable, or if they are welded in? This vid shows removal of the crossmember stud.
