tarmac2dirt Posted January 27, 2020 Posted January 27, 2020 Curious to know how much cam the renix system can handle. Looking at a Schneider cam or maybe a custom ground by bullet cam for a 4.6 stroker build. Would like something 1 or 2 steps above a RV cam. Pull up to 4800/ 5000 rpm range. Using a 5 speed and 3.55 gears. My MJ is a 1988 long bed 2wd. Hope you don't mention a Comp cams because I issues with that company. A stock cam might be the only one that works with renix f/I system I just don't know. Let me know your thoughts. Thanks
omega_rugal Posted January 27, 2020 Posted January 27, 2020 swap a 92->99 cam along with the head and intake, those are better for higher rpms
cruiser54 Posted January 28, 2020 Posted January 28, 2020 It will handle it. There's plenty of headroom in the injectors. Get a 60mm bored throttle body.
tarmac2dirt Posted January 28, 2020 Author Posted January 28, 2020 Thanks cruiser54,, actually I put a 60mm body on and 703 injectors a few years ago. Could never get the idle quit right though, pretty erratic sometimes. Thanks for the information. Paul
