mj2stay Posted September 30, 2007 Share Posted September 30, 2007 Anyone know where a good place to put an electric temp guage sending unit on a 2.5 is without taking out the idiot light sending unit? :???:If I put it in the place of the warning lights sending unit won't it mess with the ECU? Link to comment Share on other sites More sharing options...
summerinmaine Posted September 30, 2007 Share Posted September 30, 2007 Anyone know where a good place to put an electric temp guage sending unit on a 2.5 is without taking out the idiot light sending unit? :???:If I put it in the place of the warning lights sending unit won't it mess with the ECU? I'm not familiar with the 2.5, but can't you just thread a "T" fitting in there, and run both from the same place? Link to comment Share on other sites More sharing options...
mj2stay Posted October 1, 2007 Author Share Posted October 1, 2007 that's what I don't know.the sensor fits pretty deep into the head. Link to comment Share on other sites More sharing options...
Mobius1 Posted October 1, 2007 Share Posted October 1, 2007 well if it means anythng to you all I did was put in a mechanical temp gauge in. I plugged it right in where you have that bolt on the side of the thermostat. I know that really didn't answer your question but at least you have a different option and i can give you pictures if you need. Link to comment Share on other sites More sharing options...
Eagle Posted October 1, 2007 Share Posted October 1, 2007 Anyone know where a good place to put an electric temp guage sending unit on a 2.5 is without taking out the idiot light sending unit? :???:If I put it in the place of the warning lights sending unit won't it mess with the ECU? What year? If it's a 90 or earlier, I believe it's set up just like the 4.0L in the same years, and the ECU gets data from a separate sender in the driver's side of the block. The sender in the head serves ONLY the gauge (or idiot light) and can be replaced with impunity. You could always get a late model thermostat housing. That has a boss drilled and tapped for a sending unit. Link to comment Share on other sites More sharing options...
mj2stay Posted October 2, 2007 Author Share Posted October 2, 2007 Hey Mobius1, I would like to see those pics. Thats one option. And Eagle, it's an '86 and I don't recall any other sensor on the block even though there is an unused port that is plugged up, what I mean is sealed off on the drivers side.There are no other loose wires that would plug up to it. I would guess that I would put the guage sending unit in the thermostat or the block and leave the idiot light sending unit in the head,right? Does the sensor measure the temperature of the coolant or the temperature of the head itself? Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 2, 2007 Share Posted October 2, 2007 Hey Mobius1, I would like to see those pics. Thats one option. And Eagle, it's an '86 and I don't recall any other sensor on the block even though there is an unused port that is plugged up, what I mean is sealed off on the drivers side.There are no other loose wires that would plug up to it. I would guess that I would put the guage sending unit in the thermostat or the block and leave the idiot light sending unit in the head,right? Does the sensor measure the temperature of the coolant or the temperature of the head itself? the ecu temp gauge for a 4.0 is along the side of the block under the intake/exhaust... so check around the sides of your block for another one. Link to comment Share on other sites More sharing options...
