watchamakalit Posted January 16, 2020 Share Posted January 16, 2020 On the way to work this morning and I lost power to the radio and cig. Lighter. Fuse is good beyond that I havent checked much. Any ideas where to start when I get home tonight? My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t Link to comment Share on other sites More sharing options...
watchamakalit Posted January 16, 2020 Author Share Posted January 16, 2020 Update:Sat down in truck to eat lunch. Fire it up and everything working normal. Loose ground somewhere?My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t Link to comment Share on other sites More sharing options...
watchamakalit Posted January 17, 2020 Author Share Posted January 17, 2020 Leaving the jobsite this evening radio came on like normal. Before I hit the clutch to put it in gear the radio and lighter lost power again. I drove approx. one mile down the road and it came back on and began to function just fine all the way home. I really getting baffled by this one. Link to comment Share on other sites More sharing options...
Ωhm Posted January 17, 2020 Share Posted January 17, 2020 Check the terminals (poor connection/looseness) in the fuse block for the Radio fuse. Link to comment Share on other sites More sharing options...
JMO413 Posted January 17, 2020 Share Posted January 17, 2020 Has the clutch leaked on the fuse box? Link to comment Share on other sites More sharing options...
watchamakalit Posted January 17, 2020 Author Share Posted January 17, 2020 I just put a new fuse box in about a month ago. Fuses are good connections in the box are tight and clean. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t Link to comment Share on other sites More sharing options...
Ωhm Posted January 17, 2020 Share Posted January 17, 2020 Radio fuse is on a busbar with Turn Signals (TS) and Blower Motor (BM). Do TS and BM still function when Radio drops out? Link to comment Share on other sites More sharing options...
watchamakalit Posted January 17, 2020 Author Share Posted January 17, 2020 Clutch master is not leaking. Its one of the first things I check whenever an electrical gremlins shows up. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t Link to comment Share on other sites More sharing options...
watchamakalit Posted January 17, 2020 Author Share Posted January 17, 2020 Radio fuse is on a busbar with Turn Signals (TS) and Blower Motor (BM). Do TS and BM still function when Radio drops out? Yes. Blower and signals workMy build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t Link to comment Share on other sites More sharing options...
Ωhm Posted January 17, 2020 Share Posted January 17, 2020 Radio fuse goes straight to the cigar lighter and from the cigar lighter to the radio. Something not right at the cigar lighter connector or the wire between Radio fuse and the cigar lighter. Link to comment Share on other sites More sharing options...
watchamakalit Posted January 17, 2020 Author Share Posted January 17, 2020 14 minutes ago, Ωhm said: Radio fuse goes straight to the cigar lighter and from the cigar lighter to the radio. Something not right at the cigar lighter connector or the wire between Radio fuse and the cigar lighter. well the gives me an idea where to start looking ill go dive in and report back with findings.. Link to comment Share on other sites More sharing options...
Ωhm Posted January 17, 2020 Share Posted January 17, 2020 Link to comment Share on other sites More sharing options...
watchamakalit Posted January 17, 2020 Author Share Posted January 17, 2020 It also feeds the vanity lamps? I guess i don't know if those were working or not but I am guessing not. Looking like I'm not going to get into it tonight, might have to be a coffee project for the morning. Link to comment Share on other sites More sharing options...
