Ωhm Posted February 8, 2020 Share Posted February 8, 2020 Fuel Pump has three (3) sources for voltage. 1. Starter Relay during ENGINE CRANK (Battery voltage). 2. Fuel Pump Relay during KEY ON (2-3 seconds)/ENGINE RUNNING (Battery voltage - Ballast Resistor voltage drop). 3. Wide Open Throttle (WOT) (Battery voltage). O2 Heater Relay serves two (2) purposes. 1. When relay is de-energized (OFF), O2 Heater circuit is ON. KEY ON voltage is supplied for 2-3 seconds since its being fed (B+) by the Fuel Pump Relay (engine fuel prime/heater ON). ENGINE RUNNING voltage is fed by the Fuel Pump Relay all the time (fuel pump running w/ballast voltage drop & heater ON). 2. During WOT, O2 Heater Relay is energized (ON) and voltage is supplied directly to the fuel pump, by passing the Ballast Resistor. Link to comment Share on other sites More sharing options...
SuperSwede Posted April 20, 2020 Author Share Posted April 20, 2020 Finally a update! Ordered some stuff from RA in february but my package got lost somewhere by DHL, it tooks some extra weeks but RA sent me a second delivery free of charge. And what happens.. two days after that I got the second package the first also arrive! RA told me to keep it so now I got twice of everything to half the price Anyway, I put in a Bosch sensor and the Jeep works perfect. Amongst the other stuff was a water pump, thermostat housing, belt, pulleys and a clutch to the fan. I also bought new bearings to the fan, but what a disaster they are like crap out of the box, booth of them OMIX-ADA Water Pump Bearings 17104.83 Lager.mp4 Link to comment Share on other sites More sharing options...
Ωhm Posted April 20, 2020 Share Posted April 20, 2020 7 hours ago, SuperSwede said: Anyway, I put in a Bosch sensor and the Jeep works perfect. Your persistence has paid off. Enjoy the ride. Link to comment Share on other sites More sharing options...
