TNT Posted September 29, 2007 Share Posted September 29, 2007 I have a HP D60 from about a '87 F350 DRW with 4.10 gears in great shape on hold for me at a nice price. It's about 76" wide with the DRW hubs that are on it. For the rear I can get a D70 or a 14 bolt thats either 72" wide or 67" wide. I can also get a C&C DRW 63" wide 14 bolt. Choice #1 Swap the hubs to SRW ones it is about 69" wide, then shorten the long side 5" so it would be 64" wide. This would be a great match for the C&C DRW 14 bolt. With this combo I would run 8" rims with about 4" of backspacing. It would wind up about 75"-76" wide with the tires. Choice #2 Narrow the long side 5" so the axle is 71" wide. Then use a 72" D70 or a 14 bolt rear axle. For this combo I would run Hummer wheels. Overall width would be about 75"-76" wide with tires also. Choice #3 Buy the HP D60, resell it and use the money to help build my non-disconnect D30 and rear D44. I don't really wheel hard enough to need the one ton axles anymore but they would be sweet. I have a bad back so ride quaility is a big concern of mine. I'm trying to stay at about 6" of lift and am happy with 33x10.5's for street use for ride quaility. I plan on reworking the front suspension either way. What to do? This is my problem..... I have a ton of othe work to do from boxsides, to swapping the 4.0HO AW-4/242 transfer case in, to a interior swap and parting out 2 XJ's. If I sell the HP D60 I would make be a great deal for a member here. I know the D30 and D44 should hold up to how I will use them for the most part. The ride will be the best this way. But I know the bigger axles wouldn't break, but would also cause me to get on it more. I would probably have problem with the law about lift and tires with them also. So whats your thoughts??? Link to comment Share on other sites More sharing options...
Rokhound Posted September 29, 2007 Share Posted September 29, 2007 Here is my thing I am thinking about this as well. I was going to with 4 link rear and 60 front and rear. But $#!& then I would has a 200 axle with a 1000 worth of joints and steel to hold in to place. I think this would give you a great ride (I would think never really rode in a truck set up like this). But I am not willing to spend this kind of money on my $400 tuck. I think if you are only going to run 33’s and this is a DD/trail rig I think money would be best spent on a super 30 kit and some thing along the same in the rear. Link to comment Share on other sites More sharing options...
Pete M Posted September 29, 2007 Share Posted September 29, 2007 I would hesitate before adding all that weight to a rig with only 33s. Plus ground clearance would suck. I say build the 30 and 44. :D Link to comment Share on other sites More sharing options...
TNT Posted September 29, 2007 Author Share Posted September 29, 2007 I would hesitate before adding all that weight to a rig with only 33s. Plus ground clearance would suck. I say build the 30 and 44. :D My 33's will be my street tires and Q78X15's TSL's would be my trail tires. If I run those axles I'll run 37"-39.5" tires. I'm just concerned about tickets. The lift law here is 5" so I'm already over that and tires can be 4" in radius larger. That means about 35"-36" tires are max. It would cost me as much if not more to build up a Super D30 and a Super D44. They would still be weaker and have little brakes. I also have a good line on a HP D44 and a 9" combo. I will probably just regear my current axles, truss them, raise the front control arm mounts 3" and swap larger brakes on front, and put a Truetrac with alloy axles up front. In the rear I'll use a Detroit locker or spool. Then I'll just buy the HP D60 and resell it. Link to comment Share on other sites More sharing options...
pingpong Posted October 1, 2007 Share Posted October 1, 2007 I wish I would have never wasted the money building my old d30 or puttin in an 8.8. I wish when I had the "extra" income I would have built my junk on 1 tons to start with.... now that money is tighter.. I don't have the extra to drop on all the goodies.. thats why my build is taking forever Link to comment Share on other sites More sharing options...
TNT Posted October 1, 2007 Author Share Posted October 1, 2007 I don't really the "extra income" I just got a great deal on the HP D60. Here's the plan: Choice #1 Swap the hubs to SRW ones it is about 69" wide, then shorten the long side 5" so it would be 64" wide. This would be a great match for the C&C DRW 14 bolt. With this combo I would run 8" rims with about 4" of backspacing. It would wind up about 75"-76" wide with the tires. This also means I will be putting my '94 XJ back into service as a daily driver. Hopefully it will only take until spring to get the MJ ready. The one ton axles are both geared 4.10, the front will have to stay open and I will weld the rear. Regearing to 5.13 and lockers will have to wait. Link to comment Share on other sites More sharing options...
