Eagle Posted January 6, 2020 Share Posted January 6, 2020 Does anyone use it? If so, can you tell me if it's possible to delete a poor audio track and then record a narration track to go along with the video? Link to comment Share on other sites More sharing options...
Jeep Driver Posted January 6, 2020 Share Posted January 6, 2020 https://www.openshot.org/ This is what I have used. Says you can strip audio and lay down new track. Link to comment Share on other sites More sharing options...
Eagle Posted January 6, 2020 Author Share Posted January 6, 2020 Nobody uses MovieMaker? Link to comment Share on other sites More sharing options...
thecodemonk Posted January 6, 2020 Share Posted January 6, 2020 I did years ago...it was pretty easy to use. You should be able to delete the bad audio and overlay a new one on top no problem (or just mute the audio from the video and use your own instead). I know I did that when I was using it. Link to comment Share on other sites More sharing options...
shelbyluvv Posted February 1, 2020 Share Posted February 1, 2020 I did years ago...it was pretty easy to use. You should be able to delete the bad audio and overlay a new one on top no problem (or just mute the audio from the video and use your own instead). I know I did that when I was using it. Yep, exactly Link to comment Share on other sites More sharing options...
Eagle Posted February 2, 2020 Author Share Posted February 2, 2020 Sounds too easy, but I tried it and it seems to work. Thanks, Gents. Link to comment Share on other sites More sharing options...
Rambalac Posted March 16, 2021 Share Posted March 16, 2021 This article ( https://www.xp-pen.com/forum-1595.html ) is about the top 18 free and paid video editor software for Windows , Linux , Mac OS. You may check it out if necessary. I used to use Windows Movie Maker but found ShortCut to have better workflow and stability. ShortCut is able to help us edit videos by cutting, trimming, cropping, adding special effects, inserting watermarks, etc. I hope that my reply can help you. Link to comment Share on other sites More sharing options...
