omega_rugal Posted December 25, 2019 Share Posted December 25, 2019 other than the obvios ´ try next gear dip$#!& ´ does the shift up light have some other use? i mean, with my current setup, whenever i upshift i must wait for the engine to rev down a little so the gears mesh more easily, i plan to wire a switch in the clutch so whenever is pressed, propane suply is reduced, with the engine slowing down and with leaner mix it should synch and mesh faster, then i recalled that automatic transmission during shifts the timing is retarded and the mix altered to reduce strain in the transmision and make the shift invisible to the driver... i wonder if the shift up light does the same... Link to comment Share on other sites More sharing options...
Ωhm Posted December 25, 2019 Share Posted December 25, 2019 23 minutes ago, omega_rugal said: other than the obvios ´ try next gear dip$#!& ´ does the shift up light have some other use? No. Upshift Indicator is only a suggestion (fuel economy) , based on RPM's, TPS, and MAP values. Link to comment Share on other sites More sharing options...
omega_rugal Posted December 26, 2019 Author Share Posted December 26, 2019 then is more useless than i though Link to comment Share on other sites More sharing options...
cruiser54 Posted December 26, 2019 Share Posted December 26, 2019 23 hours ago, Ωhm said: No. Upshift Indicator is only a suggestion (fuel economy) , based on RPM's, TPS, and MAP values. And it's there so they could meet fuel mileage standards on the simulated driver's loop. Best use for it is remove the bulb and save it for some other location someday. Link to comment Share on other sites More sharing options...
